It is currently Thu Jul 29, 2010 10:21 pm
 Page 1 of 1 [ 2 posts ]
Author Message
 Post subject: How to mount metal models on our bases
PostPosted: Thu Jan 07, 2010 1:53 pm
Site Admin
User avatar
This tutorial explains how to use tabs of any kind of metal model to mount it on our bases without need to use pinning technique.
1.After the model is ready to be put on the base, measure with a drill bit how much of the tab should be made into pins. Most of the time - the larger the better. Personally I prefer to paint the base first before mounting the model.
2.Then with pliers cut the tab to the measured size of the pins.
3.After that paint the ends of the new made “pins” with some paint e.g. black, and place the model on the base where you want it to be while the paint is still wet to mark places where I should drill.
4.Then drill holes in marked places. Drill holes as deep as the length of the pins.
5.Add a drop of superglue into every hole and put the model in the holes.
_________________
Offline
 Profile
 Post subject: Re: How to mount metal models on our bases
PostPosted: Sat Feb 06, 2010 7:02 pm
User avatar
Many thanks for this - I've been cutting slots for them, because I make custom display bases for small display dioramas (sometimes out of Das, mostly out of MDF). I did drill into Cohen and insert pins but your way looks much simpler and easier.
The other thing I do differently is to use Plasticine in the slots to hold the miniatures rather than glue. That way I can take the miniatures out of one diorama and put them in another fairly easily.
Mind you, at the rate you are producing new Discworld miniatures, I haven't had time to take any apart yet - there's always another new miniature to get and paint! :D
Offline
 Profile
Display posts from previous:  Sort by
Who is online
Users browsing this forum: No registered users and 1 guest
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
cron
